Question about motors
55meterrov
Post by 55meterrov »
Hi all.
1.Has anyone had experience with motor vehicle heating stoves as a motor for the propeller?
I plan to use them in fresh water.
My ROV Case of 110 mm plastic tubes and quite displacement for heavy batteries and motors.
Engine options: Brush, 12V, 6.5 A, 40W,RPM 3000 per minute,weight: 1.3 kg
the size of the attached image.
they are heavy, but I do not care any will be used to power a couple of ups batteries, so that weight I and Be engines much.
If such a motor is not good, then I will reduce the size of rov for using small brushless motor.
I do not know how to experience with brushless motors from RC model, they are much better? an example of such
- Rotational speed: 930 KV
- Shaft diameter: 3.17mm
- Recommended R / C model weight: 450-550g
Dimensions: 3.6 cm x 2.8 cm x 2.8 cm
Weight: 64 g
Motors stoves are available and free of charge, and brushless motors and ESC need to be ordered from Ebay аnd this need lithium Battery.
2.Bilge pumps is brush or brushless motors?
I use a translator to talk.
auto heating stoves motor
