The New Image Resizer
Posted: Jan 12th, 2013, 8:31 am
by admin
I've added a new image resizer to to forum, pictures are still posted the same way (see the "How To" section) but are automatically re-sized to fit the forum panel when posted. Images are still the original size as you uploaded so they can still be viewed full size .....see below.....
Any time you see a little magnifying glass with the + symbol in the upper left corner (see red circle)
this means the picture can be viewed larger. Just click anywhere on the picture to view it bigger.
After the image is enlarged it should take up almost the full screen. Clicking on the picture again will
return it to normal forum size. If you see two little magnifying glasses in the top corner (see red circle)
this means the picture is actually larger and can be zoomed in once more for a more detailed look.
This time you have to actually click the magnifying glass with the + symbol.(+ is the symbol on the left)
After that you can use your slider bars (see red arrows) to move the view of the zoomed in picture
around. Click the picture once again to return to the normal forum size.
Enjoy - Below is the above picture so you can try it out on a huge picture.
Re: The New Image Resizer
Posted: Jan 12th, 2013, 8:32 am
by admin
