Hello All,
Was hoping you could comment on the following.
I found a UK supplier for acrylic domes. The price seems really good! HOWEVER, i am not sure the domes will be durable enough to meet my demands. I would like a dome that can withstand 7Bar (~100psi).
The listing for the 100mm dome has a 20mm flange, but the acrylic is only 2mm thick, (possible thinner near the center of the dome.)
I already wrote the the company, and they stated that they do not pressure test their product.
Any comment on weather or not this will be thick enough?
Thanks,
Ryan "KR2_Diving"
Dome Supplier UK - Untested
- Price List for stocked domes!
- domes.jpg (627.95 KiB) Viewed 4254 times
- bikerbones1968
Re: Dome Supplier UK - Untested
Hey Ryan, I had my dome custom built to my specifications from a US based company. The prices are fantastic and they will build you a dome whatever diameter you want and from materials up to 1/4" thick.
http://www.cleardomes.com/smalldomes.htm
Anthony
Anthony
A 4" dome .080" thick at 100 psi...... I dont think I would trust it to hold much more than 50 psi. I had a 1" thick piece of polycarbonate 10" in diamater crack at 160 psi, but then it was a flat sheet and not a dome....... at the same time ive put 100 psi into a plastic pepsi bottle and it held...for a while any way.....
