my freshwater ROV#1
streda
my freshwater ROV#1
Post by streda »
Hi there.
I'm stilll working on the blueprints jet but a I wonder if you could tell me what to pay attention for and whether my design should work or not.
rov
rov
rov
rov
The hull is made of PVC pipe DN150 with ip camera, batteries and controlls inside.
pvc pive and acrylic dome
IP cam
IP cam
I want to use the brushless motors with ecs for thusters. But I found out that I have to buy the ones with reverse. To control it I'm using Arduino Mege 2560. I'm slowly getting familiar with that with a strong support of my cousin, who is a programmer. Still wonder if I can really put these motors into the water... I'll try it when my props (44mm diameter) will be delivered.
motor and ESC
motor and ESC
brushless DC 750kV motor
I'm testing the lights made od 12V halogen bulbs.
I'll let you know when there's something new.
And sorry for my bad English.
bikerbones1968
Re: my freshwater ROV#1
Post by bikerbones1968 »
Nice looking work. It quite resembles the one I am building. Keep the picture coming.
Anthony
Silver dollar
Post by Silver dollar »
Nice drawings!
What payload will you have in the main pipe and do you know what volume it has?
I have a similar design as you and I don't need the two floating pipes as you have. On the contrary my ROV needs ballast otherwise it will float.
streda
Post by streda »
I'm planing 4 pcs of Gel batteries, controll system and the cam to be inside. The batteries are pretty heavy and about 10x15x7cm. I thought the floating pipes would help the stabilization. I'll see when I asseble all the parts of the mail hull. Also I'm pretty sure I'll have to use some ballast. Thanks for comments.
I'm wondering if a 750KV brushless motors will be enough to move my ROV.
