Achieving Large Depths
Posted: Apr 9th, 2012, 7:00 pm
Not sure how ridiculous this sounds, but just going to throw it out there:
If you wanted to achieve deep depths, without using expensive heavily enforced pipe e.t.c. could you just eliminate all air and then use a swimming float for buoyancy?
By this I mean, could you fill the camera housing with a clear resin (may be impractical to get all the bubbles out but give me a chance) and then fill the main housing with potting compound, so you basically just create a heavy brick.
Then, using an ordinary swimming float or polystyrene or similar create buoyancy.
The theory is that since you no longer have any air but still have the buoyancy you could go to much higher depths without the worry of pressure?
I know that some components can't be potted because they have mechanical parts and equally some shouldn't because they have a chance of overheating but would this be possible? Or would the floats not survive higher than average pressures?
I presume they would act like marshmallows in a vacuum (expand and then go back to normal size as it becomes less of a vacuum.
Thanks, just curious.
