PS2 controller wireless fail
shaneb24
Post by shaneb24 »
so this PS2 controller system is working so i thought but after fully testing the RF signal is not going down the tether. Any advice i soldered the tether to what i thought was the antenna but not I'm not sure.
please help the board is a MAR105 C -1
i have a send to the rov after c124, i wonder what X1 is and under the wording "L122" i looks like that may be antenna?
What would you do?
MAR105 C -1.gif (130.75 KiB) Viewed 8952 times
derelicte
Re: PS2 controller wireless fail
Post by derelicte »
x1 is a crystal (the silver can on the right).
soldering a wire to the antenna isn't going to work. antennas are tuned components. it may just look like a piece of wire, but it has very specific dimensions.
How's the rest of you control system set up?
shaneb24
Post by shaneb24 »
derelicte wrote:x1 is a crystal (the silver can on the right).
Ive heard of guys soldering from antenna to antenna via tether.
shaneb24
Post by shaneb24 »
thegadgetguy wrote:How's the rest of you control system set up?
i the ROV there is a PS2 controller board that Controls all the relays with wireless PS2 controller card with the antenna soldered to the teather to the wireless controller
http://www.cytron.com.my/viewProduct.php?pcode=PSC28A
derelicte
Post by derelicte »
shaneb24 wrote:Ive heard of guys soldering from antenna to antenna via tether.
that may work with a coax cable if the attenuation isn't too great, but a regular piece of wire won't work.
