which propeller for bilge 1100
Posted: Feb 27th, 2012, 10:26 am
by mirb
has someone tested thrust and current drain for a bilge 1100 and a 50mm 3 blade robbe or groupner or greater prop? which seam to be the best prop to be used with the bilge 1100 with best thrust and less current drain? (i'm interested in forward no matter the reverse).
many thanks.
Re: which propeller for bilge 1100
Posted: Mar 20th, 2012, 3:05 pm
I haven't done extensive tests on the Rule as I have done on the Mayfair 750's but either way I still like the 50mm 3 blade Robbe's the best.
The results for my Mayfiar tests can be found here.... http://www.homebuiltrovs.com/mayfair750test.html
