Multiple Cameras?
Posted: Jan 27th, 2012, 9:02 pm
by ERIEWRECKDIVER
Has anyone considered multiple cameras? I'm wondering about the possibility of a Front Left / Front Center / Front Right configuration. With the possibility of tilt up and down abilities.
ErieWreckDiver
Re: Multiple Cameras?
Posted: Jan 29th, 2012, 10:36 am
by Bootyhunter
Hello,
I have seen tilt and pan cameras on homebuilt rovs before, search on youtube and watch some of those videos. I think multiple cameras is also possible. I don't know how to do it myself, I just know I have seen it done. Check out Rov-in-a-box's facebook page. There is a reply from a search and rescue team and they have one of the kit built rov's with multiple go-pro cameras mounted, 3 of them I think. I have also seen a video on there with a color camera in the front of the rov and a b/w mounted on the rear of the rov. Hope this helps. If you get it going, please post some videos of the wrecks you explore with it, if thats what you are intending to do with it, thanks. Bootyhunter
Posted: Jan 30th, 2012, 10:56 am
by ERIEWRECKDIVER
Bootyhunter,
Thanks for your info. I want to see as much as I can, so I just may have multiple cameras, which involves a lot of video switching that I will need to figure out. But on a wreck seeing in different directions at the same time would be a good thing.
I assure you that I will post anything I find this summer. But until then it is R&D, then build.
Thanks Again,
ErieWreckDiver
Posted: Jan 30th, 2012, 2:15 pm
by derelicte
if you use network (ip) cameras, a single fast ethernet tether could easily support 4 or more cameras. gig ethernet would be even more. If I ever get around to building another rov, it will be ethernet based to support 2 cameras.
Posted: Jan 30th, 2012, 8:43 pm
by ERIEWRECKDIVER
WOW. I have got to figure out how to do that. For one the tether would be so much lighter.
Thanks.
Posted: Feb 1st, 2012, 10:28 pm
Yeah, in my opinion (well, my current opinion anyway
) ethernet is the way to go. Just put a switch on the ROV, and you can put network cameras, arduino, and just about anything you want down there.
