Single tether control ideas.. random thoughts
Posted: Jan 13th, 2012, 12:18 am
Hi everyone, I'm just kicking ideas around in my head for my first ROV. I tend to over-complicate things during this phase and will likely do something simpler for my first version.
I've been thinking of single tether options.. multimode fiber would be even better. It would require on-board batteries but the topside support equipment would be minimal. The downside to such a system would be controls. I'm worried about control lag involved with something like a utility on a laptop reading a joystick input, then sending that via ethernet to an Arduino. But, either way this is the system I am visualizing:
Laptop -> Fiber Media converter -> Multimode Fiber -> ROV
(there is also an option a laptop fiber card for $170 )
And on the ROV Side:
topside <- Fiber Media converter <- 4 port ethernet switch <- IP camera + Arduino ethernet
This would effectively set up a 100 Mbps network to the ROV. There is a 30 meter 50/125 startech cable available for under $30. This would be about as neutral bouyancy as you can get.
Control of the ROV would be through the laptop (joystick preferably) as well as display and recording of video. If you're willing to spend the money and could make on-board batteries work, your topside equipment would be a spool of fiber and a laptop + possibly a joystick. If precision control wasn't important, you could control through a web app on the Arduino. Use a wireless router and you could in-theory control and view with a couple of wireless devices. Something like an iPad for the video and your phone for the movement/lighting controls. The AVTech IVS 1.3 megapixel network camera is one that supports these devices.
There are alot of downsides to this though as well. While the bandwidth is good, the aditional devices take up space and power. IP cameras are expensive. You can't overlay sensor data over the video either.
Now back to reality.. I had also looked at the idea of using USB to accomplish the same. Of course you'd have to use a Cat5 cable and have a pretty strict limit to cable length.. but you could put a USB hub downside and use a USB camera, and plug the Arduino usb port in as well. This setup would be quite a bit cheaper but the bandwidth is almost useless from my guestimation.
So then I arrive back to multiple tether. I can certainly see why it is most popular. Send video direct, with overlays easily. Run a DSC and an old FM receiver downstairs and you've got easy control over your ESC's. With all these cables, might as well send some power down as well.
Ok I've probably put way too much out there for most people to bother reading all of. For those that made it this far, thanks for letting me clear my mind for the evening!
