relay board
Posted: Jan 5th, 2012, 12:33 pm
by shaneb24
what do you think?
Re: relay board
Posted: Jan 5th, 2012, 4:06 pm
by bigbadbob
hi Shane.
that looks like a lot of un-nessesary umbilical wiring. i'd reccomend using a multiplexer of some kind, velleman kit or something similar so you can have a much thinner tether for the same controll. also the cameras need power, or are you supplying this down the coax.
hope this helps and is not just criticism.
Re: relay board
Posted: Jan 5th, 2012, 4:50 pm
by shaneb24
Your absently rite but as of now I'm way over budget and the tether is built already.
Thank you i love the help and criticism.
Re: relay board
Posted: Jan 6th, 2012, 3:26 am
by bigbadbob
The LEDs need some sort of current limiting too, at the very least a resistor in each branch, but better still a proper driver circuit. drivers are cheap as chips from china.
Re: relay board
Posted: Jan 6th, 2012, 10:03 am
by derelicte
double post. sorry.
Re: relay board
by derelicte
well you are only putting 6v across 4 leds, so you don't really need a resistor. what is the forward voltage of each led?
Re: relay board
Posted: Jan 6th, 2012, 10:10 am
by shaneb24
1.5v
Re: relay board
Posted: Jan 8th, 2012, 12:52 am
by Mareike
you can buy already some 6-12V car LED Lights. I bought a chinese product 12V, 18 Leds for about 30$ each (I use 4 of them) saves a lot of soldering and mounting, just plug and play..
