No Name ROV
Posted: Aug 17th, 2011, 11:48 pm
Aloha!
I have been MIA from this forum for some months, my attentions diverted to projects that actually put food on the table. But, IIIIIIIIIIIII'm Baaaaaaaack!
In the workshop of my imagination, there have been several revisions to my earlier plans:
1. Someone on this forum mentioned they were using 2 vertical thrusters, the faster to dive to depth and to resurface. This struck me as a fine idea, and I incorporated it in the attached project. I have a little trepidation about it. I'm not sure I've located the vertical pair of thrusters such that the lifting or diving workload is divided equally between them. I imagine if it's not equally divided the whole thing may veer off this way or that. We'll see. I think I have them located to be pretty equal.
2. Another change is switching from the Rule thruster motors to the Johnsons. The Rule's wires emerge from the side of the motor housing; The Johnson's wires emerge from the rear of the motor housing. The big difference this makes is the Johnson wires can be kept entirely dry, and require no hull penetrations. It requires cutting those funny fins off the Johnson, and grinding off the raised lettering on the otherwise flat shoulder at the rear of the housing. Then, a short piece of 2" PVC sch. 40 fits nice and snug on that shoulder, ready for a good epoxy glue job. On its other end, standard fittings can be used to neck it down to integrate into the frame.
I really like having all the motor wiring completely internal. Now the only hull penetration is for the tether cables. The risk of leaks is greatly lessened.
3. Before, I was planning on using a large threaded plug at the aft end of the main hull for access to the battery packs and relays. That plan made it both difficult to work on and in serious danger of leaking. That plan also envisioned the cameras in their own housings, outside of the hulls.
The revised plan puts the cameras inside the main hull, capped with a 3/16" thick "optical" acrylic dome that fits snugly over the 4" (nominal) straight connector (5" OD) at the fore end of the main hull. There is a special adhesive for bonding acrylic to PVC. Access to the main hull is now a lathe-turned fitted joint that uses both the thickness of the pipe hull and the thickness of a straight connector over it to accomodate an O-ring seal that is drawn tight with 4 adjustable draw clamps. The joint is located to provide easy access to the cameras, the tilt servo, the relays, and the charging wires for the battery packs.
Well, I've already rattled on enough to put you to sleep. You can track these changes in the following illustrations:
