Attaching Struts to Hulls
Posted: Nov 14th, 2010, 6:26 pm
by Pilikia
I thought for sure I'd seen every kind of PVC connector that exists. I was wrong. There's a thing called a "saddle tee" worth taking a look at. Especially if you want to fasten small diameter PVC struts or braces or appendages to larger diameter PVC hulls.
They are intended for teeing small pipes off of large ones. But a simple modification allows them to be used for structural use (no fluid passage) only. They provide a large area of contact between the larger pipe and the connector, resulting in a strong solvent-based connection.
The following photos with captions should make it clear:
Re: Attaching Struts to Hulls
Posted: Nov 14th, 2010, 8:48 pm
Wow :shock: I like those .... very nice find.
Posted: Nov 18th, 2010, 5:17 pm
by Pilikia
I should have mentioned, these "saddle tees" are available at http://www.plumbingsupply.com/saddle.html
Posted: Apr 28th, 2011, 1:16 pm
by charliemac
What simple and cheap solution. Thanks for the tip!
Posted: May 3rd, 2011, 6:19 am
by HRife
Yes......these are great! I have been using the "glue and snap" ones in 3/4x3/4 and 1/2x3/4 for some time for branching new take off runs. Thanks for the link.
Posted: Feb 14th, 2012, 10:32 am
by ImmatureAthlete
Just a question regarding the saddle-t's...
Does " 2" Base x 1/2" Socket (3/4" Spigot) - 3" Length " mean that the base will fit around a 2'' PVC pipe, and a 1/2'' PVC pipe will fit inside the spigot?
Sorry, I'm just not familiar with the terms. :oops: Thanks.
