I thought for sure I'd seen every kind of PVC connector that exists. I was wrong. There's a thing called a "saddle tee" worth taking a look at. Especially if you want to fasten small diameter PVC struts or braces or appendages to larger diameter PVC hulls.
They are intended for teeing small pipes off of large ones. But a simple modification allows them to be used for structural use (no fluid passage) only. They provide a large area of contact between the larger pipe and the connector, resulting in a strong solvent-based connection.
The following photos with captions should make it clear:
Attaching Struts to Hulls
- With interior shoulder removed, the saddle fits snugly on the face of the large pipe
- SaddleTee_02.jpg (74.73 KiB) Viewed 15646 times
- Showing the interior shoulder on the right; the shoulder removed on the left.
- SaddleTee_03.jpg (87.12 KiB) Viewed 15646 times
- The front roller of a belt sander (fixed inverted in a workmate) makes grinding off the interior shoulder easy to do.
- SaddleTee_04.jpg (127.41 KiB) Viewed 15646 times
Re: Attaching Struts to Hulls
Wow
I like those .... very nice find.
I should have mentioned, these "saddle tees" are available at http://www.plumbingsupply.com/saddle.html
charliemac
What simple and cheap solution. Thanks for the tip!
Yes......these are great! I have been using the "glue and snap" ones in 3/4x3/4 and 1/2x3/4 for some time for branching new take off runs. Thanks for the link.
ImmatureAthlete
Just a question regarding the saddle-t's...
Does " 2" Base x 1/2" Socket (3/4" Spigot) - 3" Length " mean that the base will fit around a 2'' PVC pipe, and a 1/2'' PVC pipe will fit inside the spigot?
Sorry, I'm just not familiar with the terms.
Thanks.
