Building my first ROV (PC/USB controlled motors)
Posted: May 5th, 2011, 5:21 am
by Fogel
Hi all great ROV fans out there. I'm glad you found your way here to this great forum!
I've just started the tech part of my first ROV build. As soon as I get all things figured out and working I'll start the actual build. As for now I'm only focusing on the motor control and getting that sorted out.
I'm using a Velleman K8055 USB Experiment interface board. I bought it as a kit so I had to solder it myself. The kit comes with some great VB 6.0 code and .NET and there's a ton of code for C++ on the internet. If your new to writing your own code it won't take that much time figuring the demo code out. Especially if you decide to go with VB (Visual Basic) witch is the easiest language out there(?).
Just a quick thing so you dont get confused, I'll be putting comments to the pictures BELOW them in ITALICS.
Early stage
Early stage
Progress
The kit doesn't come with a USB cable so I had to buy one. The kit connects via a USB-B male connector to a regular USB-A male connector. IIRC its often used to connect printers.
Done soldering
Done soldering
Done with the soldering, I got it right the first time and it fired right up once connected to the PC
I'll be using a 1/3” CMOS camera (color) with the resolution 628x582.
The camera
The camera
I'll be running a 25m(~80 feet) BNC cable down the tether for live video feed. The cable also covers the cameras powersupply, don't know if it manages to power anything else without getting interference on the camera.
BNC Cable+RCA adapters
Two adapters at each end, both camera and grabber is RCA-female
Plexgear Grabber for live feed
Plexgear Grabber, comes with some software I'm might be using
Now a quick video I did once both camera and Velleman was connected to the PC. At the end I simulate a leakage and my custom software produces a tone and turns the background of the program red.
(Recorded with the camera I'll be using, through the 25 m of cable)
Time spent so far is about 5h.
Peace :)
*Update*
This is how I imagine it to go down, I'm not sure whether I have to relay the signals from the Vellerman before I send them down to the ROV and then relay the signal again down there. Depends on how strong the output from the card is
*Update*
I just ordered a USB extender, it converts the USB to an ordinary cat 5 network cable. Sorry for the bad eng. the plan is now to have the 8055 down in the ROV. This makes my life so much easier since I get one cat5 cable taking care of all my In and Out data.
*Update* May 9
Still waiting for the extender, I've done some thinking and just gone through the plan a couple of times in my head. I don't want to make this build to heavy on the tech side, there will always be some thing you want add to your ROV. I'm looking at a digital compass, the one Steve/Stephen uses on his HBRD3 ROV(http://www.homebuiltrovs.com/hbrd3.html). I could hook it up with my Velleman with ease but I think that hooking up a compass to a ROV designed to dive ~60f is just tacky and a waste of time. Instead I'll try to have variable speed on two of my four thrusters using the two PWM outputs on my Velleman (Here's how you do that: http://forum.velleman.eu/viewtopic.php?f=15&t=3839). The two thrusters with variable speed will be used for fw/bw movement and for steering L/R. The other two thrusters I'll mount so that I can not only dive and surface but also control the pitch.
I've got 2 test in school in the next 3 weeks so I might not be the most active user during that time but after that all of my focus will be directed into getting the ROV done.
*Update May 15*
Hi guys. I just bought 4 bilge pump. I also ordered 4 robbe propellers. 2 left and 2 right.
All of the thrusters
*Update June 1*
It has been a while since I last updated. School's out so I can focus on building now. In the last days I've bought a lot of stuff and recieved both propellers and USB extender.
Extender
Extender
I bought 2 pairs of these(just in case, one pair shown in picture) from dealextreme.com(ships from China). I'm glad I did because one pair doesn't work 100% but the other one does.
Propellers
Propellers
Robbe 50mm M4 propellers.
Relays
Relays
I'm building my own H-bridges using cheap 12v low watt relays.
I'm waiting for pieces to connect the props to the shaft of the motors. Now I'm looking for a way to waterproof the camera.
Re: Building my first ROV (PC/USB controlled motors) Upd Jun
Posted: Jun 7th, 2011, 7:06 pm
by soulreaper
Looking good. Will you have enough time to finish it this summer?
Posted: Aug 2nd, 2011, 5:13 am
by Fogel
Sorry for the late response. I'll post some pictures soon. The rov is not completed, I've finally gotten the mounts that connect the propellers to the motors so thats done. The tether is almost done. The software is pretty much done, I now use a handcontrol to send commands. Stay tuned, I might post a video.
