Hi
I have made the "basic rov control system" with joystick and the relays are clicking when i move the joystick but there isn’t any power to thrusters. What are I’m doing wrong? Any help is appreciated.
Regards steel
help plz, no power to motors
Re: help plz, no power to motors
Did I buy wrong relay? Should be 2 NO and 2 NC
If i wire the motor to pin 1 and 2 or 5 and 6 with no joystick movement nothing happens. But when using joystick the motor is running.
- H0806f618f23f4356afa3e951e371ac7fy.jpg (29.26 KiB) Viewed 51235 times
Is this the right way to read the reley
1 and 2 NC
3 and 4 NO
5 and 6 COM
7 and 8 Coil
1 and 2 NC
3 and 4 NO
5 and 6 COM
7 and 8 Coil
I think you're reading the relay right.
Here's a link for the Seafox wiring. The COM, NC and NO are different on these relays, but you should be able adapt it to your relay.
http://www.homebuiltrovs.com/howtorelaywiringdpdt.html
This is how yours should be wired. (forgive the crude drawing)
(edit - Just to be clear you need two relays per motor to control forward and reverse.)
-Steve :rov:
-Steve :rov:
Thx for the help, the releys works perfectlyIan MacKenzie wrote:I think you're reading the relay right.
thx for the drawing, i helped a lotsthone wrote: This is how yours should be wired. (forgive the crude drawing)
-Steve :rov:
