Sharing some basic Solidworks files.
Posted: Jul 16th, 2015, 9:37 pm
These are just some Solidworks files of standard Bilge Pump Thrusters Parts, PVC pipe, and some Fittings that I am sharing. Pretty basic stuff if you know CAD but these might help someone save some time in designing their Rov in the future so I figured what the hell. Files are zipped but are all in .SLDPRT format. There are a lot of PVC manufactures out there but these are about 99% correct as far as most of the outside dimensions go for the parts I had on hand.
Re: Sharing some basic Solidworks files.
Posted: Jul 16th, 2015, 9:41 pm
Thruster Parts
(Pump Tabs have been trimmed)
(Prop is just for looks. 50mm Dimension is correct but blade shape is not correct)
- Assem Thruster with Mount.jpg (55.81 KiB) Viewed 266127 times
Assembled Parts
Posted: Jul 16th, 2015, 10:20 pm
1/2" PVC Pipe & Fittings
(The look of the 1/2" 90 degree fitting is off a little but still useable.)
Posted: Jul 16th, 2015, 10:26 pm
More various Pipe and Fittings
Posted: Feb 8th, 2019, 4:53 am
by nirali31
Got your basic Solidworks files . It was much needed.
Posted: May 17th, 2019, 3:04 am
by lasikakawade
Thanks for this great post
well done
Posted: Oct 16th, 2021, 11:15 pm
by Ramjet
I've added some DXF files of the bilge pump in case that can help with your designs.
Cheers,
Ramjet.
