Sharing some basic Solidworks files.
These are just some Solidworks files of standard Bilge Pump Thrusters Parts, PVC pipe, and some Fittings that I am sharing. Pretty basic stuff if you know CAD but these might help someone save some time in designing their Rov in the future so I figured what the hell. Files are zipped but are all in .SLDPRT format. There are a lot of PVC manufactures out there but these are about 99% correct as far as most of the outside dimensions go for the parts I had on hand.
Re: Sharing some basic Solidworks files.
Thruster Parts
(Pump Tabs have been trimmed)
(Prop is just for looks. 50mm Dimension is correct but blade shape is not correct) Assembled Parts
- Mayfair 750 GPH Pump.jpg (57.15 KiB) Viewed 265965 times
- Mayfair Pump 750.zip
- (317.79 KiB) Downloaded 6495 times
- Pipe Clamp One and Half Inch.jpg (52.93 KiB) Viewed 265965 times
- Pipe Clamp One and Half Inch.zip
- (460.11 KiB) Downloaded 6698 times
- PVC One and Half Inch Pipe Motor Mount.jpg (38.65 KiB) Viewed 265965 times
- PVC One and Half Inch Pipe Motor Mount.zip
- (55.72 KiB) Downloaded 6133 times
- Prop Adapter.jpg (49.74 KiB) Viewed 265965 times
- Prop Adaptor.zip
- (529.72 KiB) Downloaded 6994 times
- Nut 4mm.jpg (41.48 KiB) Viewed 265965 times
- Nut 4mm.zip
- (192.33 KiB) Downloaded 6591 times
- Prop 50mm.jpg (41.77 KiB) Viewed 265965 times
- Prop 50mm.zip
- (282.85 KiB) Downloaded 6258 times
1/2" PVC Pipe & Fittings
(The look of the 1/2" 90 degree fitting is off a little but still useable.)
- PVC Half Inch Pipe.jpg (36.99 KiB) Viewed 265965 times
- PVC Half Inch Pipe.zip
- (50.65 KiB) Downloaded 5973 times
- PVC Half Inch T.jpg (39.67 KiB) Viewed 265965 times
- PVC Half Inch T.zip
- (164.17 KiB) Downloaded 6463 times
- PVC One and Half Inch End Cap Round.jpg (35.12 KiB) Viewed 265965 times
- PVC Half Inch End Cap Round.zip
- (116.2 KiB) Downloaded 6385 times
- PVC One and Half Inch End Cap Flat.jpg (34.12 KiB) Viewed 265965 times
- PVC Half Inch End Cap Flat.zip
- (84.28 KiB) Downloaded 6019 times
- PVC Half Inch Coupler.jpg (42.08 KiB) Viewed 265965 times
- PVC Half Inch Coupler.zip
- (100.46 KiB) Downloaded 5949 times
- PVC Half Inch 90.jpg (39.99 KiB) Viewed 265965 times
- PVC Half Inch 90.zip
- (159.76 KiB) Downloaded 6307 times
More various Pipe and Fittings
- PVC Two Inch End Cap Round.jpg (38.97 KiB) Viewed 265965 times
- PVC Two Inch End Cap Round.zip
- (141.07 KiB) Downloaded 6258 times
- PVC Two Inch Pipe.jpg (38.99 KiB) Viewed 265965 times
- PVC Two Inch Pipe.zip
- (61.25 KiB) Downloaded 6253 times
- PVC Three Quarter Inch Pipe.jpg (37.76 KiB) Viewed 265965 times
- PVC Three Quarter Inch Pipe.zip
- (50.72 KiB) Downloaded 6147 times
- PVC One and Half Inch Pipe.jpg (41.22 KiB) Viewed 265965 times
- PVC One and Half Inch Pipe.zip
- (58.84 KiB) Downloaded 6037 times
- PVC One Inch T.jpg (42.61 KiB) Viewed 265965 times
- PVC One Inch T.zip
- (155.19 KiB) Downloaded 6106 times
- PVC One Inch Pipe.jpg (39.11 KiB) Viewed 265965 times
- PVC One Inch Pipe.zip
- (57.02 KiB) Downloaded 6091 times
Got your basic Solidworks files . It was much needed.
lasikakawade
Thanks for this great post
well done
I've added some DXF files of the bilge pump in case that can help with your designs.
Cheers,
Ramjet.
Cheers,
Ramjet.
- Bilge Pump.zip
- (41.37 KiB) Downloaded 5396 times
- Bilge Pump 2.JPG (122.39 KiB) Viewed 259792 times
