This is a first look at one of the first actual production runs (well second run anyway) of the new BlueRobotics T100 thruster. I haven't actually had a chance to test it yet as it just showed up right before Xmas and I've been busy.
Anyway here's a few pictures to make you ohhh and ahhhh.
- T100-001.jpg (145.36 KiB) Viewed 19307 times
I jumped on the kickstarter as soon as I saw it and backed the thruster and added on the speed controller. They threw in the mount as a stretch goal and it's should be easy to mount to any flat surface.
- T100-002.jpg (113.71 KiB) Viewed 19307 times
My initial reaction was pure awe, these things look awesome. If these work as well as they are suppose to these are going to change the home building Rov game a lot.
- T100-003.jpg (129.58 KiB) Viewed 19307 times
The size is perfect for most of the Rov's us home builders are making.
- T100-004.jpg (102.99 KiB) Viewed 19307 times
It's about the same overall size of a bilge pump thruster with the nozzle being just around 3.75" in diameter.
- T100-005.jpg (110.1 KiB) Viewed 19307 times
This picture is a bit deceiving as the nozzle looks all scratched up. Rest assured those are just marks from when its popped out of the injection mold and are hardly visible to the naked eye. (Here they are just really accentuated by the flash on my camera.)
- T100-006.jpg (143.74 KiB) Viewed 19307 times
The blade of the prop look really tiny but this thing is suppose to put out around 5lbs of thrust.
- T100-007.jpg (193.99 KiB) Viewed 19307 times
While they do have a version with an integrated speed control I chose the external speed control encase I burn it out it testing this thing. (I'm not to versed on the Brushless stuff and I all ready fried one controller testing my magnetic drive project.
Anyway thats a quick first look, I'll post again once I test this thing out. (when ever that may be.)
