Retro- Retrofit Seafox
Post by Ian MacKenzie »
This will be my version of Steve Thone's retrofit Seafox. It's my first ROV. I'm going with this one because it's basic and I really want a manipulator. I figure if I'm spending all this time and money to go down and look for cool things, I should to be able to pick them up and take them home.
This is a work in progress. I'm constantly coming up with new ideas and changing the blueprints that exist in my head.
I'm posting pictures of what I have so far and will add more as I go along. Please speak up with any hints, tips, ideas or suggestions.
Re: Retro- Retrofit Seafox
My computer's being an A-hole tonight, and it's late, so the pictures will have to wait.
I will get them posted, I promise.
Post by a_shorething »
..... waiting.... :)
good luck!
More pictures to come, as soon as I figure out the problem with this !#$& computer.
ROV 021 C.jpg (633.98 KiB) Viewed 57014 times
Moving the side prop inside the frame raised the overall height. If it wants to nose up I might just re-build the frame work.
ROV 020.jpg (99.25 KiB) Viewed 56987 times
ROV 022.jpg (91.67 KiB) Viewed 56987 times
ROV 023.jpg (66.83 KiB) Viewed 56987 times
I found this threaded/pressure ring adapter at Rona. It's a perfect fit for the Rule pumps(1100 gph anyway) With the locking ring, it doesn't move. With out it, it can be moved a little. The back end is flared about 4mm, just enough for a mounting bolt head.
ROV 014.jpg (40.39 KiB) Viewed 56987 times
ROV 013.jpg (76.7 KiB) Viewed 56987 times
ROV 016.jpg (115.96 KiB) Viewed 56987 times
ROV 017.jpg (106.8 KiB) Viewed 56987 times
Just a regular pvc end cap. Cut a notch for the wires, drilled three holes around the outside for set screws and a counter sunk hole through the bottom to mount it.
ROV 018.jpg (80.3 KiB) Viewed 56987 times
ROV 019.jpg (96.45 KiB) Viewed 56987 times
Wow, that looks great! Nice find on the PVC stuff. (My design is looking more like a failed plumbing experiment than an ROV :lol: :), can't argue with the functionality and suitability for our stuff though, right?)
Is everything working the way you want it to?
How long have you been at it?
I started it when i was off work recovering from a hip replacement. The idea was to build and use it before i went back to work. I've been back 6 months. But it's getting there. I'm still trying to find something to float my tether that won't compress at depth.
Well it looks really good. I've been 'building' mine for over a year and I have a box of parts that may or may not one day be part of the final ROV.... :)
