OSD - On Screen Displays - Review
Posted: Nov 22nd, 2014, 11:39 am
Hey All... Those of you following my build thread will know that i have been struggling with my OSD recently.
I started with the SparkFun OSD and despite pulling most my hair out, I never got the darn thing to work.
I then ordered the MAX7456 Breakout from HobbyTronics.
The HobbyTronics OSD worked right out of the box!!!
I have put together a quick list of Pro's And Con's of each below.
Front of OSD
Front of OSD
OSD Front Side.jpg (113.32 KiB) Viewed 56082 times
  • HobbyTronics
    PRO:
    It works!
    It is much smaller. (Better for Small ROVs!)
    It comes with holes on the PCB for mounting
    Pre-Installed 8-pin JST socket on the board for power and SPI connections, and is supplied with a matching wired plug.
    Cons:
    Less of the MAX7456 functionality available.
    (Only Video in, Video Out, SPI coms, Reset, and LOS pins are available on the breakout.)
  • SparkFun
    (Ignore the fact I never got it to work!!)
    Pro:
    RCA Jacks pre-installed
    HSYNC and VSYNC are available
    More documentation and sample codes available from seller
    Passive (Video is passed through, even if BOB is not working) (Never tested this with HT OSD)
    CONS:
    Never got it to work!!
    Requires additional tinkering (adding resistors/Capacitors) to work
    Larger form factor with RCA jacks preinstalled
Back side of OSD
Back side of OSD
OSD Back Side.jpg (87.73 KiB) Viewed 56082 times
Worth Noting:
Both BOB come without any header pins soldered in. I have added those for my testing.
Conclusion:
With it's smaller form factor and Out of the box funtionality, I would go with the HobbyTronics MAX7456 OSD Break Out Board!
Re: OSD - On Screen Displays - Review
Posted: Feb 12th, 2016, 1:37 pm
by vinsub
Hello, may you post the link of max7456 library and the fonts table file? I bought a max7456 from hobbytronics like you and i need a library that works with the default fonts or a library with fonts table to upload to the max7456. Thanks
Posted: Feb 16th, 2016, 1:47 pm
by vinsub
Hallo, i tested this
viewtopic.php?f=18&t=1116&start=40
and it works!!
May you have an idea to put compass to the osd?
Posted: Feb 17th, 2016, 12:44 pm
by vinsub
I doesn't understand how "print" function works in max7456 library! If i want to print a font like the symbol of temperature "°",
Code: Select all
OSD.print(F("/xD1"));
that is in "D1" of the font file .mcm, it appears on screen, if i try, for exemple,
Code: Select all
OSD.print(F("\x55"))
to display "[" font, "U", that is in "x1F", appears!
How are fonts mapped?
Posted: Apr 3rd, 2016, 6:20 pm
by vinsub
Ok, i understand the code of osd, i changed "W" in mcm file by max software and i use i2cdev library to activate dmp of mpu6050. I compens compass for roll and pitch and i add a beautifull compass view!
Code: Select all
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
MPU6050 mpu(0x69);
#define HMC5883L_DEFAULT_ADDRESS    0x1E
#define HMC5883L_RA_DATAX_H         0x03
#define HMC5883L_RA_DATAZ_H         0x05
#define HMC5883L_RA_DATAY_H         0x07
bool dmpReady = false;  // set true if DMP init was successful
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
int16_t mx, my, mz;     //To store magnetometer readings
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
float heading;          // Simple magnetic heading. (NOT COMPENSATED FOR PITCH AND ROLL)
byte compassCalibrated = 1;
double mxMin = 0;
double mxMax = 0;
double myMin = 0;
double myMax = 0;
double mzMin = 0;
double mzMax = 0;
double mxOffSet = 18; //tested
double myOffSet = - 103.50;
double mzOffSet = - 38.5;
//==                         OSD MAX7456                         ==
// Included Libraries //////////////////////////////////////////////////////////
  #include <SPI.h>
  #include <MAX7456.h>
 const byte osdChipSelect = 10;
 const byte masterOutSlaveIn = 11;
 const byte masterInSlaveOut = 12;
 const byte slaveClock = 13;
 const byte osdReset = 0;
 MAX7456 OSD( osdChipSelect );
 // Timer
    char time[] = "00:00:00";
    char timeMillis[3];
    int msOffset = (timeMillis[3] - '0') * 100 + (timeMillis[2] - '0') * 10 + (time[1] - '0');
    bool toggle = false;
 // Fine Timer
    int z = 0;
    int x = 0;
 // Array dei caratteri per l'indicazione della bussola
    char compassOsd[] = " N - - NW - - W - - SW - - S - - SE - - E - - NE - -";
    char actualCompassOsd[] = "                    ";
    char posizione [] = {-9, -8, -7, -6, -5, -4, -3, -2, -1, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10};
// ===                      INITIAL SETUP                       ===
void setup() {
  //char compassOSD[] = {(char)1,(char)2,(char)3,(char)4};
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
        TWBR = 12; // 400kHz I2C clock (200kHz if CPU is 8MHz). Comment this line if having compilation difficulties with TWBR.
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(200, true);
    #endif
    Serial.begin(115200);
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
    // verify connection
    Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    // wait for ready
    Serial.println(F("\nSend any character to begin DMP programming and demo: "));
    //while (Serial.available() && Serial.read()); // empty buffer
    //while (!Serial.available());                 // wait for data
    //while (Serial.available() && Serial.read()); // empty buffer again
delay (2000);
    // load and configure the DMP
    Serial.println(F("Initializing DMP..."));
    devStatus = mpu.dmpInitialize();
    // supply your own gyro offsets here, scaled for min sensitivity
    mpu.setXGyroOffset(-6);
    mpu.setYGyroOffset(-35);
    mpu.setZGyroOffset(-19);
    mpu.setXAccelOffset(-3699);
    mpu.setYAccelOffset(1113);
    mpu.setZAccelOffset(1377); // 1688 factory default for my test chip
    // Magnetometer configuration
  mpu.setI2CMasterModeEnabled(0);
  mpu.setI2CBypassEnabled(1);
  Wire.beginTransmission(HMC5883L_DEFAULT_ADDRESS);
  Wire.write(0x02);
  Wire.write(0x00);  // Set continuous mode
  Wire.endTransmission();
  delay(5);
  Wire.write(0x00);
  Wire.write(B00011000);  // 75Hz
  delay(5);
  mpu.setI2CBypassEnabled(0);
  // X axis word
  mpu.setSlaveAddress(0, HMC5883L_DEFAULT_ADDRESS | 0x80); // 0x80 turns 7th bit ON, according to datasheet, 7th bit controls Read/Write direction
  mpu.setSlaveRegister(0, HMC5883L_RA_DATAX_H);
  mpu.setSlaveEnabled(0, true);
  mpu.setSlaveWordByteSwap(0, false);
  mpu.setSlaveWriteMode(0, false);
  mpu.setSlaveWordGroupOffset(0, false);
  mpu.setSlaveDataLength(0, 2);
  // Y axis word
  mpu.setSlaveAddress(1, HMC5883L_DEFAULT_ADDRESS | 0x80);
  mpu.setSlaveRegister(1, HMC5883L_RA_DATAY_H);
  mpu.setSlaveEnabled(1, true);
  mpu.setSlaveWordByteSwap(1, false);
  mpu.setSlaveWriteMode(1, false);
  mpu.setSlaveWordGroupOffset(1, false);
  mpu.setSlaveDataLength(1, 2);
  // Z axis word
  mpu.setSlaveAddress(2, HMC5883L_DEFAULT_ADDRESS | 0x80);
  mpu.setSlaveRegister(2, HMC5883L_RA_DATAZ_H);
  mpu.setSlaveEnabled(2, true);
  mpu.setSlaveWordByteSwap(2, false);
  mpu.setSlaveWriteMode(2, false);
  mpu.setSlaveWordGroupOffset(2, false);
  mpu.setSlaveDataLength(2, 2);
  mpu.setI2CMasterModeEnabled(1);
    // make sure it worked (returns 0 if so)
    if (devStatus == 0) {
        // turn on the DMP, now that it's ready
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        // set our DMP Ready flag so the main loop() function knows it's okay to use it
        //Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        // get expected DMP packet size for later comparison
        packetSize = mpu.dmpGetFIFOPacketSize();
    } else {
        // ERROR!
        // 1 = initial memory load failed
        // 2 = DMP configuration updates failed
        // (if it's going to break, usually the code will be 1)
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
// ===                    SETUP MAX7456                         ===
    SPI.begin();
    SPI.setClockDivider( SPI_CLOCK_DIV2 );      // Must be less than 10MHz.
    // Initialize the MAX7456 OSD:
    OSD.begin(MAX7456_COLS_P1,MAX7456_ROWS_P1,MAX7456_FULLSCREEN);                                // Use NTSC with default area.
    OSD.setSwitchingTime( 5 );                  // Set video croma distortion
                                                //   to a minimum.
    //OSD.setCharEncoding( MAX7456_ASCII );       // Only needed if ascii font.
    OSD.display();                              // Activate the text display.
    OSD.setDefaultSystem(MAX7456_PAL);
    OSD.clear();
  Serial.println("osd");
  // Compass OSD
// ===                    MAIN PROGRAM LOOP                     ===
void loop() {
          while (OSD.notInVSync()) {
        timeMillis[3] = (millis() + msOffset)        // The millis() function keeps
                     % 10 + '0';                //   the time even when not
        timeMillis[2] = (millis() + msOffset)        //   calculating it.
                     / 10 % 10 + '0';
        timeMillis[1] = (millis() + msOffset)
                     / 100 % 10 + '0';
        if (!toggle && timeMillis[1] == '5') {        // Converts millis() into a
          toggle = true;                        //   pulse per second.
        if (toggle && timeMillis[1] == '0') {
          time[7]++;                            // Increment on falling edge.
          toggle = false;
        if(time[7] > '9') {
          time[7] = '0';
          time[6]++;
        if(time[6] > '5') {
          time[6] = '0';
          time[4]++;
        if (time[4] > '9') {
          time[4] = '0';
          time[3]++;
        if (time[3] > '5') {
          time[3] = '0';
          time[1]++;
        if (time[1] > '9') {
          time[1] = '0';
          time[0]++;
        if (time[0] >= '2' && time[1] > '3') {
          time[1] = '0';
          time[0] = '0';
        // Add aditional code here.
      ///STAMPA "VOLT"
      OSD.setCursor( 0, -2);
      OSD.print( F("\xB3") );
      OSD.setCursor( 1, -2);
      OSD.print( F("\xB4") );
      OSD.setCursor( 2, -2);
      ///FINE STAMPA "VOLT"
      int y = millis();
      /// STAMPA TUTTI I CARATTERI DOPO VOLT
      if ((y - z)> 300){
        z = y;
        OSD.print((char)x);
        OSD.setCursor( 5, -2);
        OSD.print(x);
        x = x+1;
      /// FINE STAMPA TUTTI I CARATTERI DOPO VOLT
      OSD.setCursor( -1 - strlen(time), -1 );
      OSD.print( time);
    // if programming failed, don't try to do anything
    if (!dmpReady) return;
    mpu.resetFIFO(); //Resetta il buffer per non usare l'interrupt
    while (fifoCount < packetSize) {fifoCount = mpu.getFIFOCount();}
        // read a packet from FIFO
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        // track FIFO count here in case there is > 1 packet available
        // (this lets us immediately read more without waiting for an interrupt)
        fifoCount -= packetSize;
            // display Euler angles in degrees
            mpu.dmpGetQuaternion(&q, fifoBuffer);
            mpu.dmpGetGravity(&gravity, &q);
            mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
            //Read magnetometer measures
            mx=mpu.getExternalSensorWord(0) - mxOffSet;
            my=mpu.getExternalSensorWord(2) - myOffSet;
            mz=mpu.getExternalSensorWord(4) - mzOffSet;
           // CALCOLA VALORE BUSSOLA COMPENSATA
  double Xh = mx * cos(ypr[1]) + my * sin(ypr[2]) * sin(ypr[1]) - mz * cos(ypr[2])*sin(ypr[1]);
  double Yh = my * cos(ypr[2]) - mz * sin(ypr[2]);
  float heading = atan2 ( Yh, Xh );
  if(heading < 0) heading += 2*PI;
  if(heading > 2*PI) heading -= 2*PI;
  int headingDegrees = heading * 180/M_PI;
           //FINE CALCOLA VALORE BUSSOLA COMPENSATA
           //float heading2 = atan2(my, mx);
            //if(heading2 < 0) heading2 += 2 * M_PI;
            Serial.print("\t");
            Serial.print("ypr\t");
            //Serial.print(ypr[0] * 180/M_PI);
            //Serial.print("\t");
            Serial.print(ypr[1] * 180/M_PI);
            Serial.print("\t");
            Serial.print(ypr[2] * 180/M_PI);
            //Serial.print("\t h:\t");
            //Serial.print(heading2 * 180/M_PI);
            Serial.print("\t");*/
            //Serial.print("mag : ");
            //Serial.print(headingDegrees);
            //Serial.println("\t");
            // STAMPA I GRADI DELLA BUSSOLA SULL'OSD///
           /* if (headingDegrees >= 100) {
              OSD.setCursor( 12, 0);
              OSD.print(headingDegrees);
            else if (headingDegrees <= 9) {
              OSD.print("0");
              OSD.setCursor( 13, 0);
              OSD.print("0");
              OSD.setCursor( 14, 0);
            else if (9 < headingDegrees < 100) {
              OSD.print("0");
            /// FINE STAMPA I GRADI DELLA BUSSOLA SULL'OSD///
            /// DIREZIONE BUSSOLA
            int centralInitOsdCompass = map(headingDegrees, 0, 360, 0, 51);
            for (int y = 0; y < 20; y++)
               int osdCompassArrayFinal = centralInitOsdCompass + (posizione [y]);
               if (osdCompassArrayFinal > 51) {osdCompassArrayFinal = osdCompassArrayFinal - 51;}
               if (osdCompassArrayFinal < 0) {osdCompassArrayFinal = osdCompassArrayFinal + 52;}
               actualCompassOsd[y] = compassOsd[osdCompassArrayFinal];
              OSD.setCursor( 3, 0);
              OSD.print(actualCompassOsd);
              Serial.println(actualCompassOsd);
              OSD.setCursor( 13, 1);
              OSD.print((char)214);
// Local Methods ///////////////////////////////////////////////////////////////
  byte isLeapYear( int year )
    if (year % 400 == 0) return 1;
    else if (year % 100 == 0) return 0;
    else if (year % 4 == 0) return 1;
    return 0;
  //end isLeapYear(
This is a video! Thanks for your forum!
https://youtu.be/SmG_v0pG3RE
Posted: Apr 13th, 2016, 2:21 am
by vinsub
I add pitch visualization!
https://youtu.be/EfBuItIzvCA
Posted: Nov 16th, 2019, 11:26 am
by Chimpusmaximus
Hi
Do you have a copy of the latest code at all i could take a look at, just about to look at this aspect and would be interested in what may already be available.
Chris
