I'm going to make ROV by myself with really control so I'll use brushed motors. I have already water-sealed old drill motor and tested it with computer cooler fan propeller. While testing I found out that motor took 1.5A when I run it without prop. When I add the propeller took motor about 5A in the air and 10A in the water while I'm running them with 12V. The biggest problem is that relays max ampere is 5A. I know that the shape of the propeller is far too aggressive and I'll buy new propellers as fast as I can. How ever here is a photo of my thruster:
So the question is does anybody know any good (and cheap and powerful enough) brushed motors and propellers for the thrusters? Motors must take under 5A when you are running them underwater with 12V. Hope that someone can help me whit this problem.
