Types of PVC pipe.
Posted: Aug 21st, 2014, 3:30 pm
Is ducting pipe suitable underwater or is this different from proper PVC pipe? It is a lot cheaper.
https://www.homebuiltrovs.com/rovforum/
The PSI rating of PVC is usually printed on the outside. I think the stuff you're referring to is what I would call 'vent pipe' and it's made of a different type of PVC (or could be ABS in fact) which is NOT pressure rated at all because it's just designed for use in venting gasses at 1 atmosphere of pressure. I wouldn't recommend it because it's probably going to have unpredictable consistency (one piece might withstand 30 psi while another length may develop cracks...).Domes wrote:Is ducting pipe suitable underwater or is this different from proper PVC pipe? It is a lot cheaper.
