2s or 3s batteries for onboard power?
Posted: May 1st, 2014, 2:01 pm
by TigerShark
I am going to use the same 750KV motors from hobbyking along with 55mm Graupner props that many are using here. Since the thrusters draw huge amounts of current at 12V would running them at 7v on a 2s battery be better? I can get more 2s batteries in my housing to ge more Ah to extend run times.
Is anyone else running 2s for onboard power?
Re: 2s or 3s batteries for onboard power?
Posted: May 2nd, 2014, 6:14 pm
Thinking more manageable low-speed control, and not wanting full power I used a 7.2 volt ni-mh RC car pack. Also was more suitable in size/shape if I went up to bigger cells, so much the same logic as your's. IMO, the true motor thrust versus current draw, and the controllability at different battery voltages is best done by experiment using the intended ESC. Check the ESC specs re voltage input
Higher voltages will mean a lower current draw than lower voltages for a given power at the motor - this in theory will result in less interference and reduce the current demand on wiring and connectors. Hope that helps
Posted: May 13th, 2014, 12:11 pm
by TigerShark
After more testing I figured out most of my current loss was due to small gauge wire (30A vs 10A) so I can use the full voltage of the 3s without too many amps so I ordered two with 10Ah capacity total.
