main power extension cord
Posted: Apr 30th, 2014, 12:28 pm
by Brodgesell60335
Hi. Was thinking 30m of 12 gauge outdoor extension cord for thruster power. Aside from weight issue is there something I am missing? Some reason not to use it? Thanks.
Re: main power extension cord
Posted: May 1st, 2014, 1:53 pm
I think the weight is the only reason no one uses them. It's going to be one heavy tether and not very flexible at that. Keep in mind not only do your thrusters have to move your Rov they have to be able to drag all that tether around too.
Posted: May 1st, 2014, 1:57 pm
by TigerShark
I stripped out two conductors from the outer insulation and used that on mine. It was cheaper than buying the wire seperately. You will find the diameter and weight to be an issue with the outer insulation.
Posted: May 2nd, 2014, 8:18 pm
by scubersteve
Try 100% copper speaker wire. I used some 10 gauge stuff off of ebay and it was very flexible.
