Two brushless outrunners parallell on one ESC
Posted: Feb 26th, 2014, 11:58 am
by Kale
I want to use two up/down thrusters. Can I connect them together assuming the ESC can deliver the current needed.
/Kale
Re: Two brushless outrunners parallell on one ESC
Posted: Feb 26th, 2014, 12:03 pm
by olegodo
I have investigated this myself, but found out that it was a bad idea and would most probably not work or ruin your ESC.
Running two ESC's of the same signal should work though.
Please someone correct med if i'm wrong.
Posted: Feb 26th, 2014, 12:42 pm
by Kale
Ok, better safe than sorry. I will use two ESC.
Thanks!
/Kale
Posted: Jun 9th, 2014, 3:13 pm
by TigerShark
If you angle the two thrusters a bit you can run them opposite directions of each other to get lateral movement (crabbing) of the ROV which will make the use of another ESC more appealing.
