The code difficult for me
Rayan works with the test code with your Bill but does not work well. From the picture you can see what happens. What do you think? If you come to Italy we eat a pizza together. Sorry for my bad English
- Cattura.JPG (32.62 KiB) Viewed 3480 times
Re: The code difficult for me
KR2, are you out there? No posts for a while. Zotta, is the baud rate the same at both ends? I am not familiar with the code but you could probably use a much lower speed as well. This already pointed out in your previous thread
rossrov wrote:KR2, are you out there? No posts for a while. Zotta, is the baud rate the same at both ends? I am not familiar with the code but you could probably use a much lower speed as well. This already pointed out in your previous thread
control immediately
thanks rossrov
