Manipulator Seal
John
Manipulator Seal
Post by John »
Hi All,
I am building a manipulator and I need to purchase some LIP TYPE OIL SEALS. Can anyone give me a clue as to where I can find them? All I can seem to come up with are automotive large seals. I live in Huntington Beach, California. I am a new member and have enjoyed checking out all of the ROV's that you folks have assembled, but never seen anywhere about where to find the seals.
Thank You, John
Re: Manipulator Seal
(I know I all ready emailed you directly but for the benefit of others I'll post it here too :D)
A good place to find smaller seals is a motorcycle shop, the seals I used for my thrusters as well as the manipulators are small motorcycle oil seals. The particular ones I use fit a 6mm shaft are made by Honda. The Part number is either 91205-MJ0-003 or 91256-428-003 (I think I used the first part number but if I remember correctly both are 6x16x5 in size.)
Below is a variety of seals you can find at a motorcycle shop. The ones on the left are oils seals and the ones on the right are valve type seal (which I'm not to sure would work to well I haven't tested them yet)
Post by Ian MacKenzie »
Did either of you have any luck with these?
I used the oil seals on my manipulator without any problems. I haven't tested them past 40' but I guess they will go further than that.
