Raspberry Pi camera board
Posted: Jun 30th, 2013, 6:11 pm
by ponken6
Hey guys, what do you think about having this camera onboard a ROV? http://www.adafruit.com/products/1367
It costs 30 dollars and is very tiny, it also has great resolution. 1080p/30fps (!)
I'm planning on mounting one of those on my future ROV.
Tell me what you think about this little piece of awsomeness!
Re: Raspberry Pi camera board
Posted: Jul 1st, 2013, 11:36 am
by dna1990
If it has good low-light performance and you are going Pi for control, sounds great and very affordable.
Unless using a clear dry box approach with camera in same (akin to OpenROV), then you might need to work out a round cable approach to better exit the dry box and reach the camera location.
Could it handle multiple cameras?
Posted: Aug 13th, 2013, 11:40 am
by Zaibach
Using it for an ROV was actually my plan for the RasPi camera when I bought it.
My only real complaint about it is that I wanted to incorporate a pan/tilt system and the flat cable it uses to connect to the RasPi isn't exactly super bend/flex friendly. It probably won't be a problem, especially if you are going to have a static camera but its something to consider.
I haven't really played that much with the video quality yet since everything is still in the early phases of what to use and how to code. Tho from the little I have played with it, it seems like a competent little camera.
Posted: Aug 13th, 2013, 1:57 pm
by ROVER3D
Please be careful using PCB-Cameras with fixed-optic. YOU NEED FISHEYE (120°+) to navigate your ROV under water. This cam i think its about 70°. Ask divers who professional film under water...
