Rob's ROV
robe_uk
Rob's ROV
Post by robe_uk »
Hi all
I've been working away on my ROV over on http://www.rcgroups.com/forums/showthre ... 054&page=7. Just thought I'd post a link to it as I already had that thread running when I discovered this forum, otherwise I would have had the thread here on homebuiltrovs.
Activity over there is almost non existent :roll: but hopefully someone here might get some ideas from the thread.
Cheers Rob
Re: Rob's ROV
Looks really sharp! Like the vectored thrust arrangement!
Have you had it in the water yet?
robe_uk
Re: Rob's ROV
Post by robe_uk »
Thanks,
No not been in for any action yet other than the wheelie bin tests for buoyancy, hope to get some real life testing done soon, I've a mini SD video recorder on order so should be able to record any action.
Rob
jconduto
Re: Rob's ROV
Post by jconduto »
Very impressive your project. What kind of glands or penetrators you have used to connect the cables to the hull?
robe_uk
Re: Rob's ROV
Post by robe_uk »
jconduto wrote:Very impressive your project. What kind of glands or penetrators you have used to connect the cables to the hull?
Sorry I missed your question,
I have fed the connectors through the rear bulk head, motor wire feed throughs described here http://www.rcgroups.com/forums/showpost ... stcount=65
And the umbilical described here http://www.rcgroups.com/forums/showpost ... stcount=71
I have changed from the single buoyancy chamber on top to two as shown here http://www.rcgroups.com/forums/showpost ... stcount=98, this had made it more stable in testing.
robe_uk
Re: Rob's ROV
Post by robe_uk »
Added picture of ROV to this thread to save everyone from having to jump over to other forum, I have received my sd card video recorder and hope to get this into the control box this week then I'll try and get some real world testing done.
