Lighting array
Lighting array
This is my lighting "array" for my first rov. i might add more Leds to it but i want to see if these will work in my water
- wiring
- image (6).jpeg (563.48 KiB) Viewed 37224 times
- 3 Leds, one jumbo and one normal on the 90* bend, 1 poked out the side of the pipe
- image (5).jpeg (475.52 KiB) Viewed 37224 times
Re: Lighting array
Depending on the clarity of the water, inland lakes tend to have less visibility, and the minimum lighting your camera requires will drive how much light you will need. Our ROV uses four 3 watt luxon LED modules, and at 60 feet in an inland lake we needed more light.
Once you get it assembled, let us know how it worked.
Rover
Rover
