RC transmission through tether
- bikerbones1968
Re: RC transmission through tether
I know why. you have to set one channel as master one as slave.
- bikerbones1968
BigAL Have you programmed the ESC's correctly? This is another thing to make sure you have done correctly? Have you tested each motor and ESC one at a time on a single channel to make sure you do not have a bad motor or ESC? Are you using a BEc circuit or a RX battery?
Do t know what I did but set up a new model and it works?
- bikerbones1968
LOL thats great congrats. prob just missed a step programming the controls.
Hi bikerbones
Could you help me a little with my dsc cable as I belive you have one.
Couple you test it out and tell me the cables used to which pin on the plug and battery harness please.
I will be posting some pic of how far I have got tommorow I hope
Al
Al
- bikerbones1968
Get those pics posted so I can see what you got.
hi here are some pictures of progress so far need a lot of work yet but at least its watertight had it in the pond for a week and no leaks fans for motors on there way from China so stuck a bit till they arrive
Al
Al
- DSCN1753.JPG (663.12 KiB) Viewed 7097 times
- DSCN1752.JPG (649.04 KiB) Viewed 7097 times
- DSCN1751.JPG (615.18 KiB) Viewed 7097 times
- DSCN1750.JPG (654.47 KiB) Viewed 7097 times
- DSCN1749.JPG (695.99 KiB) Viewed 7097 times
- bikerbones1968
BigAl999 wrote:Hi bikerbones
Al
It should be pretty straight forward, the PPM signal can be placed on any spare channel and only requires two conductors to make it work. You only need the ground (usually Black) and the signal wire (usualy orange) from TX to the RX. The center pin on the RX leads are for 5VCC power.
- bikerbones1968
I like your main body. What is it constructed with?
The body is 5 mm cast acrylic sheet that I bent myself with a small gas torch
The 2 sealed tubes are 100mm acrylic tubes with drain inspection ends.
The 3 thruster tubes are 75mm acrylic tube
Hope to get some more work done on it soon
Al
Al
