Page 15 of 16
Re: I'm jumping in!
Posted: Jul 23rd, 2015, 5:04 pm
by Bubbles
Nice job!Wiring is a big headache !!!
Re: I'm jumping in!
Posted: Jul 23rd, 2015, 8:07 pm
"Hackish" ???? All thing considered it looks like a hell of a job to me, nice work looks very professional.
Re: I'm jumping in!
Posted: Jul 24th, 2015, 8:53 am
by a_shorething
Hey Ole!
Remember when we first started on this journey?
I don't know about you but I thought it would be a six-month project at most. Ha ha.
I don't do much work on mine in the summer months so it's taken me forever to make progress. I'm hoping the hardware side won't be as difficult as the software/logic side has been for me.
Yours is coming together nicely. I'm following along jealously from afar!
Re: I'm jumping in!
Posted: Jul 29th, 2015, 3:17 am
by olegodo
Oh yes! I was also sure it would only take a few months!
My tendency to change my plans almost at a weekly basis is the biggest fault for the long time it is taking.
Always some new ideas, discovering problems and so on.
Hope you get going on your soon!
Re: I'm jumping in!
Posted: Aug 5th, 2015, 3:48 pm
by a_shorething
olegodo wrote:Oh yes! I was also sure it would only take a few months!
Thanks, I think I've only change the "General" design a few times, but every time I log on here I learn something new and cool that I want to try. Also, I'm stubborn about the mag-coupled thrusters. I can't give up on them, but I haven't had enough success to warrant confidence...
Following along....
Re: I'm jumping in!
Posted: Sep 8th, 2015, 4:22 pm
by olegodo
Small update
Cam tube is now almost finished.
Cabling and one more piece to print before its finished.
Inside are 3d printed parts.
One servo for rotating/looking vertically. About 160-170 degrees of movement.
Two lasers spaced 12cm apart for rough size measuring and just looking cool.
One cheap 720p ip camera witch will have a lens with a bit of zoom to better see the manipulator.
One Hikvision DS-2CD2032-I 1080P high quality camera. It does 1080p@30fps and can also do 2048×1536@20fps. But the smoother 1080p looks better. A wider angle lens will be used on this one.
I am also considering a different layout where I remove the low quality cam and add a gopro instead.. At least its possible to do.
Connection in the end is a AN6 hose, connection thingy.. Same connection in my WTC. I can fit 10 pairs of cat5 leads through (removing the outer jacket of the cat5 first)
Re: I'm jumping in!
Posted: Sep 10th, 2015, 7:45 am
by a_shorething
Looks cool!
Can't wait for sea trials....
Re: I'm jumping in!
Posted: Sep 15th, 2015, 5:16 pm
by olegodo
I have now finished the cables and and hose that will connect my WTC to the camera housing.
As mentioned I have used AN6 fittings and managed to get 9 pairs of UTP cabling through it making a total of 18 leads. Should be enough.
It was an extremely difficult process, started out with 12 pairs bud had to pull out 3 to get it all the way through.
The inner diameter of the hose is bigger then the fittings, so I cut up 3 pieces of 3mm nylon 3D printer filament to tightly pack the hose. This should keep it from compressing when under pressure from the outside.
I also needed a spacer inside my camera housing and I thought "why not pimp it up a little?" So I printed the spaces with what is now my ROV's name on it.
I made the letters recessed, primed it and painted with some silver spray paint that I had laying around. After it dried, I sanded it down so that only (or mostly) the recessed letters still had paint. Not the best finish, but looks ok
The name Draug1 I got from old Norwegian folk tales that tells of a ghost, or monster of the seas called Draug or Draugen. Kind of random idea, but I liked it
Next step is to solder connectors to the cables, connect everything and see if I broke anything
Re: I'm jumping in!
Posted: Sep 15th, 2015, 7:20 pm
Very Sharp looking!
Love the 3D printed components!
I really need to get me a printer!
I am curious, why so many wires?
Re: I'm jumping in!
Posted: Sep 16th, 2015, 3:19 am
by olegodo
Each cam needs 6 wires. two for power, four for signal.
I haven't checked the amp draw of the cams yet, but maybe I can supply them both from just one pair.
The lasers needs two leads and the servo needs 3 leads.
So in worst case I need 17.
I would like to have a temp sensor and/or a leakage sensor in there, but seems I might be out of luck.
