ROVER3D
Re: ROVER3D
Wow, that is truly amazing ROVER3D. Have you gotten to try it out in the water yet?
ROVER3D
Re: ROVER3D
Post by ROVER3D »
RoverII at Elba, Italy
martinw
Re: ROVER3D
Post by martinw »
Sweet 8-)
Martin
Deakel
Re: ROVER3D
Post by Deakel »
Dude that's AWSOME!!! How does the hull hold up under pressure?
ROVER3D
Re: ROVER3D
Post by ROVER3D »
The hull does not hold up the pressure. the electronic components build in an oil-filled housing inside the hull.
gumma
Re: ROVER3D
Post by gumma »
Truly amazing job!! Did you use epoxy resin or polyester resin for hull?
ROVER3D
Re: ROVER3D
Post by ROVER3D »
thx 8-)
i used epoxy resin. Don´t use polyester! You cannot use polyester in saltwater for longer time, you cannot clean the rov with alcohol or aceton and you may have problems with painting. i had a lot of problems with it so i can´t recommend polyester for rov-building...
gumma
Re: ROVER3D
Post by gumma »
I had debate with my colleagues, so i guess i won because i've done my hull using epoxy!! Tnx 4 reply!
olegodo
Re: ROVER3D
Post by olegodo »
ROVER3D,
How long can you typically run your ROV with that battery pack?
And how long does it take to charge it back up to 100%?
ROVER3D
Re: ROVER3D
Post by ROVER3D »
hey olegodo,
this is a very difficult question. whats a typical use?
sure it will run 4h in halfmode.. but my current rov isnt tested.
when i dimm leds to 80% they only take 50% of full-current. so there are many things you can do to stretch operating time.
Loading time at 6A:
