Page 2 of 2
Re: Use of Velleman k8023 as control system
Posted: Dec 4th, 2011, 12:09 pm
by bigbadbob
This is my setup-
You can also remove D1-D4 from the reciever and replace D3 and D2 with wire links. just make sure you mark the +12 and 0v terminals.
Posted: Dec 11th, 2011, 12:18 pm
by bigbadbob
The k8023 could also be converted very easily to provide comms over fibre optics instead of the current loop.
Audio system TOSLINK fibre optics would work fine. just replace the input transistor (and it's associated resistors, led etc)of the reciever with a TORX177 and at the controller end you'd replace the transistor and its associated components with a TOTX177 , you'd have to connect vtx- of the controller to gnd as well.
Posted: Dec 11th, 2011, 1:12 pm
by bigbadbob
OK. i just looked up the transmission distance using those part numbers and you'd get about 5 m. lol.
However there are plenty to choose from here-
http://media.digikey.com/pdf/Data%20She ... OSLINK.pdf some are good for 1000m.
Posted: Feb 9th, 2012, 10:00 pm
by shaneb24
Has any one heard of MX013 10 ch Encoder / Decoder Module?
http://www.bakatronics.com/shop/item.aspx?itemid=459
It sounds like the K8023 but its way smaller
Posted: Feb 11th, 2012, 2:52 am
by Kjetil
I have tried that one. You can only press one button at the time. On the K8023 you can pres all at once.
Posted: Feb 11th, 2012, 3:05 pm
by shaneb24
Thats a bad design
Thanks for the heads up now i know what not to buy
Posted: Feb 19th, 2015, 9:19 pm
by himcgrew
Hey everyone, with the velleman do you need a specific type of wire for the serial communication? Also how would you wire it up to a switch on the controller end.. Whenever I do it never seems to work the lights never come on only the two power lights. The relays I am using are small enough to be powered by the reciever end but I can't seem to get it to work, any simply way to explain this to me? Thanks, help would be appreciated.
