Gui 2.0 =0
jason howard
Re: Gui 2.0 =0
Post by jason howard »
nothing tags a project explanition better than an evil laugh ;)
GUI
Re: Gui 2.0 =0
Post by GUI »
New photo.
derelicte
Re: Gui 2.0 =0
Post by derelicte »
dumb question:
why would you need a generator and an inverter?
I like your bilge pump clamps. did you buy or fabricate those clamps?
thanks!
GUI
Re: Gui 2.0 =0
Post by GUI »
Go to lowes and you will find them.
The generator and invertor is to run GUI for long periords of time. I have been able to run GUI for over 5 hours on one tank so far =)
derelicte
Re: Gui 2.0 =0
Post by derelicte »
maybe I should have worded my question differently.
both the generator and the inverter make ac voltage. why do you need both?
do you primarily run off a battery and use the inverter to make the ac and just use the generator to charge the battery?
GUI
Re: Gui 2.0 =0
Post by GUI »
There isnt a need for a battery in this setup. Its all dc voltage passed the inverter. Gui runs on dc power
:mrgreen:
derelicte
Re: Gui 2.0 =0
Post by derelicte »
so the generator only makes dc?
does the inverter run a computer?
I'm still not seeing why you need both.
fluffy111
Re: Gui 2.0 =0
Post by fluffy111 »
Generator make VAC. Inverter invert VAC into VDC. VDC is use on ROV but he can still use VAC for computer (if he does).
Regards
fluffy
derelicte
Re: Gui 2.0 =0
Post by derelicte »
that could be my confusion. I've always heard that inverters convert dc to ac, not the other way around.
http://en.wikipedia.org/wiki/Inverter_(electrical)
if his "inverter" takes in ac and outputs dc, then it is a power supply, not an inverter.
that makes sense.
Re: Gui 2.0 =0
Yea, I'm confused too. Most American generators generate DC and have a built in inverter which converts to AC.
