Page 2 of 2
Re: Laser Cut ROV Project
Posted: Apr 22nd, 2015, 12:34 pm
by Ian MacKenzie
Sexy. What's it rated for depth wise?
Posted: Apr 22nd, 2015, 2:32 pm
by crd
Ian MacKenzie wrote:Sexy. What's it rated for depth wise?
Its rated for 200ft, more than enough for what I need
Posted: Apr 22nd, 2015, 2:44 pm
by crd
Just bought this one too for $44 shipped
Posted: Apr 26th, 2015, 10:05 pm
by sprayed150
have you used a camera housing before? if so what kind of luck have you had with it? would you build a small frame around it to mount the equipment and use the dry cell section for camera and electronics only, just having the wire penetrations to a minimum?
Posted: Apr 27th, 2015, 2:04 pm
by crd
sprayed150 wrote:have you used a camera housing before? if so what kind of luck have you had with it? would you build a small frame around it to mount the equipment and use the dry cell section for camera and electronics only, just having the wire penetrations to a minimum?
This is my first time with everything ROV, the camera housing is rated for 200' so Im guessing I will not have a problem with water penetration on 50-60ft. I will make a separate housing for the ESCs though.
Posted: Apr 27th, 2015, 3:32 pm
by crd
Got the motors, ESCs, Props, Dive flashlight, gripper this week, Im only waiting on the camera housing.
The flashlight is rated 1200lm and is only 1 mode, I will have 2 of this wired to a RC switch, they have 3 orings. $7 each. Not bad. The gripper will require some modification to make it waterproof.
Posted: Apr 28th, 2015, 8:21 pm
by crd
Received the first camera housing today,
I like it, is a little heavy but works excellent so far, I played with all the knobs and no water came in, I will be sealing them anyway and only leave 3 for wiring to come out, but this thing is strong and very well made. I might need to redesign the motor mount frame too, to fit this housing.
Posted: Apr 28th, 2015, 8:22 pm
by crd
