working with mechanical seals to waterproof motors
Erik102696
Re: working with mechanical seals to waterproof motors
Post by Erik102696 »
Steve strikes again! You always have the answers to almost everything thanks. I will look into your test. Also I haven't heard of u seals but it sounds interesting. Does anyone know of a good supplier of oil seals or seals like it?
You can give http://www.mcmaster.com a try they have a little bit of everything. :D
amarillo_rocket
Post by amarillo_rocket »
I am using V-Ring seals from Mcmaster Carr PN9572k31. Have only tested to 8ft so far. The smallest diameter is 1/4". I used several "telescopic" pieces of brass tubing to increase the size of the shaft. I will attach pictures if I can get them resized small enough to add.
