Page 2 of 3
Re: Plans For a Ducted Fan
Posted: Aug 18th, 2013, 11:21 pm
by bikerbones1968
Hi Guys, these ESC's http://www.hobbyking.com/hobbyking/stor ... verse.html are well suited for your needs. They "reverse" at around 85% of the forward max RPM. Many of the boat ESC's only reverse at 15% to 20% of their forward max RPM.
Posted: Aug 19th, 2013, 10:58 am
by fryslan76
Thanks Biker, I was trying to remember who here on the forum was using these :) the manual even says 100% for reverse.
Posted: Aug 19th, 2013, 12:49 pm
by bikerbones1968
They indeed could be 100% in reverse. I know they work and work well.
Posted: Aug 19th, 2013, 2:37 pm
by jsut210
Ordered a few today...Now we wait :lol:
Posted: Aug 19th, 2013, 2:43 pm
by fryslan76
Did the same 5 minutes ago. Lets see how fast they arrive in the Netherlands.
Posted: Aug 19th, 2013, 4:17 pm
by marcane
Most ESC need two reverse signals, the first brakes the motor and the other one reverse it. If you fin a esc with rock-crawler mode you can put the motor in instant reverse, this will ease the programming a bit.
Marcus
Posted: Aug 19th, 2013, 5:08 pm
by bikerbones1968
If memory serves me well you can turn the brake function off with the programming card on these ones. I could be wrong its been a while since I programmed these. ;)
Posted: Aug 19th, 2013, 5:15 pm
by jsut210
Here's the manual: http://www.hobbyking.com/hobbyking/stor ... 509X21.pdf It looks like mode "two" might be promising. Mode "two2" looks like what you were talking about with the brake.
Posted: Aug 19th, 2013, 5:26 pm
by bikerbones1968
Yep that's it. Jogged my memory when I read the manual. Works exactly as described. Lets just say that the transition from full forward to full reverse happens fast enough it does not compromise the full effect of control. People have to remember that we operate in a fluid and a few millisecond pause on thruster direct will have no ill effect on performance.
Posted: Aug 19th, 2013, 6:27 pm
by jsut210
I wonder where they got "two2" I guess it takes real creativity not to use "three" :lol:
