Laser Cut Frame, Camera Housing ROV Project
Re: Laser Cut ROV Project
Sexy. What's it rated for depth wise?
Its rated for 200ft, more than enough for what I needIan MacKenzie wrote:Sexy. What's it rated for depth wise?
Just bought this one too for $44 shipped
- image.jpg (155.87 KiB) Viewed 6556 times
- image.jpg (131.16 KiB) Viewed 6556 times
sprayed150
have you used a camera housing before? if so what kind of luck have you had with it? would you build a small frame around it to mount the equipment and use the dry cell section for camera and electronics only, just having the wire penetrations to a minimum?
This is my first time with everything ROV, the camera housing is rated for 200' so Im guessing I will not have a problem with water penetration on 50-60ft. I will make a separate housing for the ESCs though.sprayed150 wrote:have you used a camera housing before? if so what kind of luck have you had with it? would you build a small frame around it to mount the equipment and use the dry cell section for camera and electronics only, just having the wire penetrations to a minimum?
Got the motors, ESCs, Props, Dive flashlight, gripper this week, Im only waiting on the camera housing.
The flashlight is rated 1200lm and is only 1 mode, I will have 2 of this wired to a RC switch, they have 3 orings. $7 each. Not bad. The gripper will require some modification to make it waterproof.
- IMG_2793.JPG (222.45 KiB) Viewed 6520 times
- IMG_2791.JPG (200.53 KiB) Viewed 6520 times
- IMG_2789.JPG (312.68 KiB) Viewed 6520 times
Received the first camera housing today,
I like it, is a little heavy but works excellent so far, I played with all the knobs and no water came in, I will be sealing them anyway and only leave 3 for wiring to come out, but this thing is strong and very well made. I might need to redesign the motor mount frame too, to fit this housing.
- IMG_2813.JPG (214.51 KiB) Viewed 6498 times
