I'm jumping in!
Bubbles
Re: I'm jumping in!
Post by Bubbles »
Cool video and nice performance!!!Are you willing to share the printing file for this type of blade?Results are really good!
Great job ;)
olegodo
Re: I'm jumping in!
Post by olegodo »
Hmm, not quite sure how I feel about that as it is very similar to the Bluerobotics thrusters. :?
Bubbles
Re: I'm jumping in!
Post by Bubbles »
Ok.no problem!!
Re: I'm jumping in!
olegodo wrote:Hmm, not quite sure how I feel about that as it is very similar to the Bluerobotics thrusters. :?
Isn't that a lot like not wanting to share your hamburger recipie because McDonalds sells hamburgers?
Not that you necessarily need to share it anyway, but I wouldn't let any similarity bother me.
olegodo
Re: I'm jumping in!
Post by olegodo »
Valid point.
However I emailed Bluerobotics an asked for permission, explaining that I based my design on theirs and they had no problem with it as long as I mention that it was inspired by their design.
So if you haven't already, check out their site http://www.bluerobotics.com ;)
Files added to my shared dropbox folder in the first post in this thread. "PrintpropBLUEROBOTICS.stl , .stp , .ipt"
Re: I'm jumping in!
olegodo wrote:Valid point.
Well that is very sporting of them!
Makes me like them even more.
Re: I'm jumping in!
Thanks for sharing your files that's really cool of you to do, I'm sure a lot of work went into the design. Can't wait to try printing one myself. :D
Re: I'm jumping in!
Olegodo,
Incredible work! I am VERY impressed with the detail and professional look of your documentation! (and I have only opened your .pdf so far!)
I wish the mechanical prints I worked with on a daily basis were as well organized as yours! Keep up the GREAT work!
Ryan
"KR2_Diving"
olegodo
Re: I'm jumping in!
Post by olegodo »
Thanks for the kind words.
I really like doing this stuff for myself only. At work, we have pretty strict design rules to follow at all times. Here... not so much :P
Not much work has been done the last couple of days, but I am playing with the idea to maybe use the same type brushless motor that I use in the thrusters to run my manipulator. It might be a silly idea.
What I want to try is to model a 80:1 worm gear that can be printed. Then using this as a winch I should be possible to use for tilting and clamping my manipulator. What needs to be seen is if I can get enough torque out of it. We will see, work in progress. Maybe it will just make the esc's make pretty smoke :)
Also got a lot of new filament for my printer, so I had to make a new rack to hold the spools.
PLA in the back and ABS in the front.
Re: I'm jumping in!
Post by a_shorething »
Hey Ole, you might want to look up some hi torque gears for that manipulator thing. I think I sent you some links before. They basically just have a little gear set mounted on the end of a regular motor, but it reduces the RPMs down as low as like 70 or 80 rpms (or up to like 600 IIRC) but it's much lower than the several thousand that you typically get from a small motor and the torque is pretty good.
