I'm jumping in!
Re: I'm jumping in!
Yes you should be fine with that. I've been reading about guys going down 100+ feet with frames made from 1" tubing. I just finished cutting 60+ feet of 1/2", 3/4" and 1" pipe with a steak knife (broke my saw and never replaced it) so my plan better work lol
Re: I'm jumping in!
Well, since the frames in these designs are flooded, you can go to the mariana trench with the frame itself. The rest though, not so much.
Re: I'm jumping in!
Yes ideally you'd make a flooded frame. I didn't think about that lol.
Re: I'm jumping in!
So I did some work today. See the "draw, thrust, and components" thread in the Thruster forum: viewtopic.php?p=8367#p8367
I also made a new chamber that I can use to treat my 3d printed parts with acetone vapor. This process gives the parts a smooth surface and also a bit more flexibility and strength.
As we all love pictures.. here are some pictures with comments!
- Blades being printed.
- 2014-08-06 18.38.08.jpg (262.6 KiB) Viewed 4940 times
- Simple kitchen storage container. Note that I have removed the gasket so that it never gets pressurized. Very important!
- 2014-08-06 19.23.35.jpg (253.82 KiB) Viewed 4940 times
- The platform for the printed parts lifts out with the lid.
- 2014-08-06 19.23.54.jpg (160.33 KiB) Viewed 4940 times
- Blade sitting in acetone vapor
- 2014-08-06 19.45.30.jpg (168.64 KiB) Viewed 4940 times
- Treated prop blade to the left. Untreated to the right
- 2014-08-06 22.17.00.jpg (552.27 KiB) Viewed 4940 times
Re: I'm jumping in!
That's a pretty awesome finish, I was reading about that acetone trick and it looks like it works great. I'm going to have to get some ABS and give it a try myself soon. Thanks for posting this....
Re: I'm jumping in!
How long do you leave them in the acetone? I imagine not too long.
Re: I'm jumping in!
Somewhere between 5 and 10 minutes on that piece.
Re: I'm jumping in!
Does anyone know of a very flexible/soft hose type? Around 1" size or bigger.
Needed to be used for pressure compensation of my battery and electronics compartment.
Thanks for any input!
Re: I'm jumping in!
How about an innertube of a bike wheel?
Re: I'm jumping in!
Wow!
That's a really good idea actually!
Although the rubber don't like sea water that good, it should be quite ok as long as it is cleaned with fresh water after every use, as everything else.
Thank you for idea!
Thank you for idea!
