Hi there,
I'm Magnus AKA Kale from the southern part of Sweden. I have been scuba diving for many years now and I have carried out a lot of video filming under water. My father helped me building my first video housing many years ago (He is not with us anymore). The housing is made of stainless steel and I have always seen it as a great ground plate in an future ROV project. The future is here now and I'm looking around the web for input.
My plans are so far:
Control:
Before I found this place I was planning to control the ROV with one Arduino UNO at the surface and one in the ROV, communication via RS485. Having seen several successful projects using RC-controller via DSC (direct servo control by wire), I'm in doubt…
Thrusters:
Four unprotected brushless outrunners equipped with rc-boat propellers. Two at the rear and two on the sides for up/down.
Hi from Sweden
Hi from Sweden
- My video housing is going to get new clothes...
- housing.jpg (72.83 KiB) Viewed 7297 times
Re: Hi from Sweden
Welcome,
That tube looks like a nice starting point for a ROV
only then you cannot create any cool underwater movies of the ROV in action anymore after the build.
Have fun building.
Fryslan76
Have fun building.
Fryslan76
Re: Hi from Sweden
Wow! great 'pod' how deep have you used it?
Also is it positive buoyant in water? What kind type of camera did you use (& will it be the same in the Rov?)
Nice to have you around by the way.
Regards
Regards
Re: Hi from Sweden
Hi guys and thanks!Billrose wrote:Wow! great 'pod' how deep have you used it?
Regards
It's more than ten years since I used the housing. It was originally constructed to contain a Canon Hi8 camcorder. The last camcorder I used in the housing was a Panasonic 3CCD DV camera. Then I bought an aluminum housing for the Panasonic camcorder and the old "Miss Piggy" was retired after a long and faithful service.
I have been down to about 45-50 meters with the old housing. It was equipped with a 10 mm flat plexi on the former rear side. As you may see I have shifted so the former rear side is now the front going to be equipped with a dome. I'm sure that the housing can withstand several hundred meters with sufficient thickness of the dome.
It weights about 5 kg and is slightly positive buoyant when empty. I will adjust the buoyancy with a some foam on top if it is necessary.
My plan is to use a high definition Full HD board camera. Like this one maybe:
http://www.ebay.com/itm/151122186572?_t ... EBIDX%3AIT
It's a HD-SDI camera. I assume that the signal is hard to transfer so I plan to record the uncompressed signal within the housing and transfer a compressed signal to the surface monitor… Well, thats the plan of today. Let's see what tomorrow brings…
Take care!
/Kale
Re: Hi from Sweden
Hi Kale,
I like that camera, but I want to try to avoid any noise from other electronics in the sub so am looking at This one on Hobby king.
I'm not a camera guy so it may be very inferior to what you're looking at, but it fits the pan and tilt frames and also does the recording in house. That at least should negate any noise from long (+100mm) cable runs within the ROV, I don't mind if the picture that is viewed whilst diving is a bit noisey.
Re: Hi from Sweden
Great! That seems to be what I should start with. Thanks!kenl wrote:Hi Kale,
Re: Hi from Sweden
I have done some testing today. Everything seems to be ok.
https://www.youtube.com/watch?v=Diczu2Gkupo
Re: Hi from Sweden
Nice work Kale, I look forward to your open water film!
Re: Hi from Sweden
Thanks Ken! I hope I can do a harbor dive this week. My tether is only 10 meter long...kenl wrote:Nice work Kale, I look forward to your open water film!
