Finally got my custom designed thruster housing completed!
Had a friend print them out on his home built 3D printer.
They took 6hrs each to print, but they look AMAZING!
Mark, if you stumble across this page, thanks a million!!
3D Printed Thruster Housing
- KR2_Diving
- thruster5.jpg (249.21 KiB) Viewed 8475 times
- thruster4.jpg (240.15 KiB) Viewed 8475 times
- thruster3.jpg (249.14 KiB) Viewed 8475 times
- thruster2.jpg (241.54 KiB) Viewed 8475 times
- Thruster1.jpg (222.29 KiB) Viewed 8475 times
simpleben77
Re: 3D Printed Thruster Housing
AWESOME!!!!
autonomousROV
Looks great!
How thick are they and how strong are they? I've long thought about buying a 3D printer but didn't want to waste the money if they could not build pressure tollerant pieces (down to at least 200').
Looks nice. I am wondering why you left so much clearance between the prop and the shroud? Don't you loose a lot of power that way?
- KR2_Diving
fryslan76 wrote:Looks nice. I am wondering why you left so much clearance between the prop and the shroud? Don't you loose a lot of power that way?
not sure how thrust will be affected, haven't had a chance to get these wet yet.
the design was suppose to be a bit tighter, but for some reason I thought I had 55mm props, when in fact I have 50... other then that, no real reason...
- bikerbones1968
Ok Ryan I need 4 of those NOW!!! LOL Actually can you get the CAD file, .obj, .stl or whatever file was used to create that? I know a guy not far from me that has a 3D printer and makes custom RC parts for FPVers. I would love to get them printed out.
fireslayer26
Yes yes, please share! Those look great! What was the cost?
that is awesome good work!
