The three stainless glands on top are pneumatic fittings made by "Legris" with taper threads that screw into the pvc hull.
The 8mm od pneumatic pipe push fits into these just like push fit plumbing fittings.
The piece of cable in the top one is a test piece (the brass ones are blanking plugs)and is 6mm od cable which is a tight fit in the 8mm pnumatic pipe and will be glued on the final build but it passes the vaccum test no problem.
The vacuum test only simulates down to 10m but gives a good indication that all is well.
Hope this helps someone.
