i cant decide if i should keep the battery in for mobility, or out for easy charging...
Control box
Control box
This is the control box for my first rov. lots of wiring for those 4 little switches..
- Wiring with Vex 7.2v battery
- image (4).jpg (496.4 KiB) Viewed 5894 times
- top view
- image (3).jpeg (618.58 KiB) Viewed 5895 times
Re: Control box
I would leave it in the box if it fits as it would be less bits to worry about and carry about, it's hard to tell from the pic but I would put a small power switch on it if it doesn't have one so not to flatten the battery if one off the switches is accidently operated in transit, its a pain in the you know what when that happens!!
- ROVEnthusiast
Re: Control box
Is that little battery enough power for your rov? I have to use a 12v motorcycle battery that is 22Ah for my rov.
