Control box
Aphire
Control box
Post by Aphire »
This is the control box for my first rov. lots of wiring for those 4 little switches.. :P
i cant decide if i should keep the battery in for mobility, or out for easy charging...
Wiring with Vex 7.2v battery
image (4).jpg (496.4 KiB) Viewed 5895 times
top view
top view
image (3).jpeg (618.58 KiB) Viewed 5896 times
hazzyb
Re: Control box
Post by hazzyb »
I would leave it in the box if it fits as it would be less bits to worry about and carry about, it's hard to tell from the pic but I would put a small power switch on it if it doesn't have one so not to flatten the battery if one off the switches is accidently operated in transit, its a pain in the you know what when that happens!!
ROVEnthusiast
Re: Control box
Post by ROVEnthusiast »
Is that little battery enough power for your rov? I have to use a 12v motorcycle battery that is 22Ah for my rov.
