Boat Blower thrusters?
Aphire
Post by Aphire »
i saw this thread from a while back, i was wondering if there was a way to make them water tight?
Rover
Re: Boat Blower thrusters?
Post by Rover »
Boat blowers are somewhat airtight, Designed to keep any flammable fumes away from the arcing of the motor brushes, but are not specifically designed to be water tight at depth.
Even with that said, you may want to run one submerged, the motors will run underwater totally wet. With the extra drag of the water the impeller is moving, how may amps would the motor draw, and is it over loading the rated motor amp draw. Water has a lot more resistance to flow then air does.
Let us know how your testing goes.
Rover
DavidF
Post by DavidF »
ive played with a 4" attwood blower, it works but draws way too many amps.
http://www.youtube.com/watch?v=tP50ajpb ... ahmmmYbb2A
merbass
Post by merbass »
How much did they draw in your tests?
DavidF
Post by DavidF »
Pegged a 20 amp meter, best I can tell ya.
