Burnt out ESC (RC over tether question)
m_g
Re: Burnt out ESC (RC over tether question)
Post by m_g »
ah ok, that seems simple enough, thanks a bunch...
What if I wanted counter-rotating props (ie one left hand prop, one right hand prop), if i reverse the wires on the motor to ESC side, will that cause a similar issue to what i had before? (I know, counter rotating props really don'tmatter, but that's how I have it set up, so to avoid changing/ordering new props...)
two motors on one channel_mg.jpg (62.7 KiB) Viewed 3065 times
bikerbones1968
Post by bikerbones1968 »
You are correct. Just swap only the wires connected to the motor. If one is turning the wrong way reverse them so it will rotate in the direction you want it to turn. Glad I could help.
m_g
Post by m_g »
awesome! thanks bikerbones-much appreciated
m_g
Post by m_g »
Ok, success!! Thanks everyone for your help.
I've replaced the burnt out escs, and now each motor has its own esc and wiring-working flawlessly-just need to pot it up.
Cheers
Mg
