ROV progress
bikerbones1968
Re: ROV progress
Post by bikerbones1968 »
Now the female Banana plugs, with wires pre soldered are slipped through the holes. A little touch of epoxy on each one and push them into the hole. Actually they fit so tightly in the holes I had to use a common nail and a rubber hammer to drive them in the right depth. Once the epoxy has had time to setup and fully cure. I will fill the "well" with QSIL 216 two part silicone sealant just to the top of the plugs. On the inside "well" I will first pour a thinned down firberglass resin this should lock everything in place around the solder joints and down into the holes. When that has had a chance to cure over night I will fill the remaining 1" interior "well" with more QSIL 216. If all goes well its back to the lake for another submersion test to verify I am still leak free.
internal wires.jpg (32.06 KiB) Viewed 18507 times
Last edited by bikerbones1968 on Sep 22nd, 2012, 5:58 pm, edited 6 times in total.
DavidF
Re: ROV progress
Post by DavidF »
not much longer and well be seeing some under water video!!! :D
bikerbones1968
Re: ROV progress
:( At this pace I will be another two months and will be chopping a hole in the ice to go for a dive
bikerbones1968
Re: ROV progress
I have been thinking about how to make standoffs for motor mounts coming off of the Hull. So I thought the potting well idea seemed to be quite secure and held in place by just the glue so why not fabricate another PVC coupling and test it out on a scrap piece of Hull. Well I glued it on and cargo strapped it in place for the night. With the Hull locked tight in the bench vise and both hands firmly grasping it I can pull the entire 8 foot work bench with a couple hundred pounds of tools on it across the floor. It won’t budge. The only way I could break the bond was with a four foot pipe and a substantial amount of force. I think that should be more than sufficient. :lol:
bikerbones1968
Re: ROV progress
Thought adding a easy way to carry the ROV with a handle would be good. I may laminate a 1/2" thick piece of PVC directly on the top of the ROV to give lots of material to attach the handle to.
carry handle.jpg (47.07 KiB) Viewed 18507 times
Re: ROV progress
Lookin pretty sweet!!!
Keep us posted!
bikerbones1968
Re: ROV progress
Thanks KR2. Still sooooooo much to do.
bikerbones1968
Re: ROV progress
The first bit of sealing is done sealing the brass sockets in the exterior "potting well".
Potting topside.jpg (52.55 KiB) Viewed 18496 times
bikerbones1968
Re: ROV progress
Ok everybody I need to name this thing something other than ROV project. I have never been too good at giving things names Ie my 10 year old male cat only responds to "Man Cat" So I am leaving it up to you to be creative and name this project. LOL I will draw from all the submissions from a hat and that will be its birth name. This name will be air brushed on the completed project and all over youtube when I get to the point I am capturing videos of my dives.
This should be entertaining and I may regret this LMAO
Cheers Anthony
Re: ROV progress
"Man Cat II"
I can think of no better name! :)
And if you fell of your chair when you read this, you know the name has to be! :) I think a fierce tiger cat paint job would be appropriate as well!
:D
