Onboard batteries
Sky
Onboard batteries
Post by Sky »
Hey all
Was considering if running onboard batteries would be better since I read that the battery to esc lead on a brushless esc shouldnt be lengthened otherwise it could damage the esc. Is this true?
What batteries would be best suited for onboard use
Lipo, SLA or NiHm/Nicd?
Can a brushless esc suited for lipo and Nihm/Nicd be connected to SLA batteries and a PSU?
And How can You work out approximate runtime of a battery (dont want like 10 minutes runtime with onboard :mrgreen: )
Philipp
Forest
Re: Onboard batteries
Post by Forest »
if you where to use batteries for power you should probable use lipos because you will get a longer run time. but if you use batteries it will in cress weight.
what are you going to use to control your ROV? :)
Sky
Post by Sky »
Hey
Ill be using a arduino. Yea I think SLA or niCd/nimh would be better since they decrease buoyancy :)
Lipos are probably also a not so good idea since they can catch on fire ect
I already asked this in another thread but how can the pc to arduino cable be extended easily by 100ft besides using usb/ethernet extenders?
Philipp
Spadinator
Post by Spadinator »
Li-pos only catch fire if they are damaged. I have been running Li-pos in aircraft for a while and have even crashed them with out a problem. They have a longer running time and less bulk and weight of batteries of the same rating. The only thing that I would recommend is that you insulate them to keep them warm. They have diminished capacity in the cold.
ROV-Control
Post by ROV-Control »
The image shows Lipoly Packs broken in 60m depth. No fire just damaged by shorten circuit.
